Lights Dimming
Old Sep 25, 2005 | 12:26 PM
RICAKILLA's Avatar
RICAKILLA
Default Lights Dimming
Sup all, i been noticing at night while driving, if i start to get on it, my head lights will dim a lil, is this normal? I did have a 'Check Charging System' light pop up a few times on the message center but it went away a few seconds later...Any Ideas?
Old Sep 25, 2005 | 11:15 PM
The Ghost's Avatar
The Ghost
Default RE: Lights Dimming
Not right, even with underdrives. If you are turning RPM thats when your alternator should be at highest output. You should never see a Charge system warning. Take it to your dealer.
Old Sep 26, 2005 | 01:40 AM
ford4v429's Avatar
ford4v429
kinda sounds like maybe engine torque is pulling a connection somewhere...
Old Sep 26, 2005 | 02:09 PM
millergt's Avatar
millergt
Sounds like a bad alternator or connections. If you don't get it checked out and fixed your battery will be toast as well.
Old Sep 26, 2005 | 04:03 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
YUP...
NOT right..... Have dealer check it out.
Old Sep 26, 2005 | 05:01 PM
ChristopherCamel's Avatar
ChristopherCamel
most defintally a crappy alternator that is either failed or starting to fail...when the begin to go they give out a varying voltage..hence the headlight flicker, i know that cause it happened on my old mustang last summer..took me all of 30mins to pop a new one in...you probably just got a crappy one id take it in and complain
Old Sep 26, 2005 | 05:08 PM
Orion_240's Avatar
Orion_240
Are you sure it's not just the force of acceleration pushing the eyeball back into the socket. If your eyeball gets pushed in you lose all sight! That's what they do when cutting the cornea when performing Lasic Eye Surgery!
Old Sep 26, 2005 | 07:48 PM
RICAKILLA's Avatar
RICAKILLA
LOL Orion, nice one.. thanks for the replies guys, ill be calling the Stealership tomorrow to start bit&^ing
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
