Reverse does not work
Old Jan 21, 2019 | 05:06 PM
08'MustangDude's Avatar
08'MustangDude
Banned
Not sure a Pan drop is 8 quarts, but should have this much on hand, just in case...
It's 12 Quarts for a dry-fill.
5-Quarts for a drain plug removal and fill.
5.5 to 6.5 for pan drop and filter. Got to take into account, the saturated filter...
I think eight would over-fill it, but doing the fill procedure will drain what's not needed all back out
anyway. Removing the reverse servo MAY produce another pint+ in fluid loss...
I modified a 1 gallon bug sprayer to fill transmissions that have to be done this way...
Old Jan 22, 2019 | 04:07 AM
ilde30's Avatar
ilde30
Originally Posted by Derf00
You most likely do not need to rebuild the transmission.
It is possible and just as simple that, the Reverse servo needs to be taken out and cleaned.
In the ASTG Technical Buliten 08'Mustangdude posted (that shows the reverse servo and its components), the Reverse Servo Molded Piston has a black rubber like seal that is used to create the hydraulic pressure that engages the reverse gear. If this seal gets hardened, cracks, tears or gets stuck from dirt, pressure does not get built up like it is supposed to so, you lose reverse gear.
That servo piston is available by itself as PN 4L2Z-7D189-AA
The other seal in there called the Inner 'D ring seal' is PN 2L2Z-7423-AA
To access the servo you need to drain the fluid and drop the pan. It's four simple bolts. Then dismantle the servo, clean everything, install a new piston and seal and reassemble the servo before reinstalling into the transmission. You will need about 8 quarts of MERCON V or equivalent fluid to refill the transmission. While you are in there you may as well replace the transmission filter (two additional botls).
Thank you very much, this weekend I will take you to the workshop to check reverse servo and if it is wrong I will buy a new one, thank you very much
Old Jan 22, 2019 | 04:08 AM
ilde30's Avatar
ilde30
thank you!!
Old Jan 22, 2019 | 12:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
It was 7.5ish with the pan drop, filter replacement, servo removal/cleaning,and a valve body removal/tear down for upgrading when I did it the last couple of times. Considering how many problems you can have when you under fill these transmissions, 8 quarts will leave him with some fluid for the power steering system should he need to top off or want to swap some of the fluid out.
Old Feb 3, 2019 | 01:34 PM
07 Stang's Avatar
07 Stang
Not trying to be a smart A$$, but how does "Reverse does not work" fit in the Appearance Section?
Old Feb 3, 2019 | 02:15 PM
08'MustangDude
Banned
It "appears" that reverse doesn't work?
Old Feb 7, 2019 | 08:21 PM
pascal's Avatar
pascal
S197 Section Modder-ator
You are not a smart *** and thanks for spotting that on...
I just moved thread in the general discussion where the OP should get more traffic anyway.
Old Feb 8, 2019 | 08:20 AM
outceltj's Avatar
outceltj
now thats funny
ashleyhead04
Aug 4, 2014 01:40 PM
maestro1024
Feb 20, 2011 05:28 PM
MegaBill
Jun 6, 2007 03:13 PM
InferRedd
Jan 22, 2007 02:26 PM
rudemood12
May 31, 2006 02:13 AM
