Electrical Question?
Old Sep 15, 2019 | 11:16 AM
Grouper's Avatar
Grouper
Default Electrical Question?
2008 What is the story on Shaker 500 System running with the ignition off? Thanks a lot
Old Sep 15, 2019 | 11:54 AM
proeagles's Avatar
proeagles
That question leave a lot to the imagination. It can run for a few minutes after shutting off the ignition until or until you open the door. Or it could be running because there is something wrong with your ignition switch. Maybe somebody on here will have a good answer for you.
Old Sep 15, 2019 | 12:00 PM
Grouper's Avatar
Grouper
Thanks, just started reading on it sounds like a lot of people have had problems with it...
Old Sep 15, 2019 | 06:12 PM
JScatt's Avatar
JScatt
Doesn't it turn off after you open the door? It should
Old Sep 15, 2019 | 07:09 PM
Grouper's Avatar
Grouper
It wasn't on, at all just started making a noise like changing the disc's and the battery went dead. Thanks, for reply...
Old Sep 15, 2019 | 08:34 PM
bl817's Avatar
bl817
pretty common problem with the Shaker 500. there are some threads, mostly early ones that describe this issue. your radio is going out. you can replace with another Shaker 500 unit or upgrade to a new touch-screen Bluetooth, USB, CD/DVD head unit. I recommend going thru Crutchfield and picking one out with the options you want. they will add the mount/dash kit, harnesses (which you will need 2 metra ones if you have door subs) and if you choose to upgrade your speakers, the harnesses for those as well for free. FYI, there are a lot of HD radio channels in our area. if you need any help, send me a dm, I can install no problem.
Old Sep 16, 2019 | 03:47 AM
Grouper's Avatar
Grouper
I guess what you are saying is the Shaker just sits there and goes out? I am going to take the battery cables off today and put my 6 amp battery charger on it to see if it will take a charge. I will put the cables back on and listen to the Shaker, and see what is going on. I purchased from Crutchfield a long time ago for another car, good outfit. Any other thoughts would help. Thanks for your input...
tazmax
May 27, 2012 03:55 PM
dwsracing
Jan 22, 2010 03:46 PM
godfather_go3
Jan 16, 2010 10:02 PM
crazyemi
Dec 20, 2007 04:09 PM
Ken M
Nov 1, 2006 08:25 PM
