Oil Pressure Help
Old Apr 14, 2020 | 05:40 PM
JacJ's Avatar
JacJ
Default Oil Pressure Help
I changed lash adjusters and rocker arms(Ford Performance) on my 09 GT and now have no oil pressure. It was fine before I installed new parts. All electrical is hooked back up correctly and soaked the lash adjusters before installing. Car was only down for 2 days so I don't believe the oil pump would need to be primed, but I also did that. Any suggestions short of replacing oil pump? Hard to believe it's the pump.
Old Apr 16, 2020 | 01:36 PM
hammeron's Avatar
hammeron
if you still have the oil pressure sender unit disconnected, the PCM will show a low oil pressure warning
on the dash. this happened to me, and the solution was to attach a wire from the sender to engine ground.
after installing the sender, the warning light should go away.
Old Apr 16, 2020 | 02:32 PM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Did your engine make any abnormal noises such as a loud tapping after you started it up? If it sounded normal and quiet, the engine did have oil pressure and the problem is either a bad gauge sending unit or the wiring connector is disconnected/broken.
joes90gt
Sep 28, 2010 06:13 PM
Billymac76
Dec 3, 2005 11:33 PM
88GT40
Apr 3, 2005 12:47 AM
luckypballer
Feb 21, 2005 08:09 PM
Sean2116
Apr 18, 2004 10:12 PM
