Purchasing a 2012 Boss 302
Old Dec 3, 2020 | 09:13 PM
YFD_322's Avatar
YFD_322
Default Purchasing a 2012 Boss 302
Hello all. I'm in the midst of purchasing a 2012 Boss and it only has 1 key. Starting to do some research I know now they have the M-9603-MBTKA but where would I find or is it possible to get the red key? Any help would be much appreciated.
Old Dec 5, 2020 | 05:06 AM
pinn's Avatar
pinn
This is what I found online - (If you lost the red key then you will need to purchase a replacement key from the local Ford dealer and have it cut to match your ignition switch before installing the Trackey software at the dealer.)
Old Dec 5, 2020 | 06:18 AM
YFD_322's Avatar
YFD_322
thank you. Curious, how does the tune know to match the red key? I mean if you download the tune it seems any key would run that tune I wonder how it knows to use the red key only
Old Dec 7, 2020 | 11:49 AM
hammeron's Avatar
hammeron
this explains it pretty good, i was always curious as well and now i know.
https://www.motorauthority.com/news/...k-key-detailed
"Ford created a dual-patch powertrain control module to avoid the complexity issues that would arise with two PCMs."
Old Dec 31, 2020 | 07:16 PM
RedKey's Avatar
RedKey
Do you have to buy the $680 pack with it?
Old Jan 7, 2021 | 11:07 AM
Derf00's Avatar
Derf00
Gentleman's Relish
I'm sure the answer depends....
If you want to piecemeal it you MIGHT be able to get it to work but, if you have problems, you're going to be paying for support or hardware replacements to get any problems fixed. The cost of support will quickly eat up any savings you may have gotten from piecemealing it out and could actually end up costing you more.
If you pay the $680 package price, hardware and some basic connectivity issues are covered under warranty.
It's up to you.
Old Jan 8, 2021 | 02:37 PM
RedKey's Avatar
RedKey
Thanks for the reply. I didn't want to piecemeal it at all. Actually, I bought just a red key replacement and took it to the dealer and they programmed it for 69.00.
KonaBlue302
Apr 4, 2020 04:29 PM
Jouhaux
May 16, 2015 07:21 PM
DocSnickers
Feb 4, 2013 10:50 AM
swata
Jan 24, 2008 02:59 AM
GTAProject
Oct 15, 2007 12:28 AM
