Oil Type
RE: Oil Type
A few misconceptions
oil can go 15000 miles: Sure can, but filters generally cant, so unless you want your filter to clog up and the bypass on your filter to open up and crap to start flowing through your engine change that oil every 5000 miles or so. Their is nothing wrong with changing your oil within the first 1000 miles either, its a GOOD idea.
Synthetics vs Dino-bone, synthetics just last longer: Not true, synthetic oil is far superior, molecularly finer and a far better lubricant. The ONLY con to running synthetic after your break in period is the price(90% of break in is done in the first 50 miles BTW, and their is a lot of debate weather to drive it hard or baby it, make your own choice).
I personally dont go over 2500 miles between changes on dino-bone oil, I would rather loose the 500 miles on every oil change than loose my engine 100k miles early.
My mustang will only ever see synthetic after the the 2nd oil change
Never run thicker oil than what is recomended in the book, oils have changed a lot in the last 10 years, a 5W20 now protects better than many of the 50W racing oils of the past. Thicker oils will not go through the oil passages properly, and can starve your motor. When ford tears down your now siezed, oil starved motor and checks the oil viscosity your warrantee is shot and now your paying for a new engine, the install and fords teardown time. If your engine croaks with the proper oil in it then you have a warantee to cover it. As far as oil pressure goes, their is a reason why higher viscosity oil gives higher pressure readings... because it doesnt flow as well! You all know what that means. You can have 800lbs of oil pressure and it does you no good if the oil doesnt move.
RE: Oil Type
Stick with what the owner's manual recommends. I get Motorcraft 5W-20 and Motorcraft oil filters at Walmart for about $12.
All you ever wanted to know about oil and more: www.bobistheoilguy.com
I recommend that y'all check out all the threads on 5W-20 before experimenting!
Hope this helps.
Mike
Hope this helps.
Mike
RE: Oil Type
ORIGINAL: FrdMstnggt99
Just made my 2nd oil change on Saturday. I am now running Quaker State High Horsepower Full Synthetic. I believe it is 5W-30. No problems. Slight improvment.
mrappe
09-26-2015 10:16 AM
