Handling Performance Any questions about suspension, steering, tires, or rims can be asked here!
Steeda UCA S197
Old 05-15-2013, 08:33 PM
Danno-23
Danno-23's Avatar
Default Steeda UCA S197
Installing my Steeda UCA and mount for my 2006 GT, and I am running into this issue that I assume everyone else has?
The new mount bracket for the forward mounting bolt is a LOT shorter than factory, so I am wondering where the clamping force is coming from to tighten this bolt instead of just crushing the sheet metal under my back seat.
Ah screw it, Steeda knows what they are doing don't they???
So, sure enough I go to tighten this bolt under the seat, and it feels like its never getting tight, but rather just crushing the metal under my back seat, which you can see in this next picture, as the washer is curling up around.
Its like it is still trying to "pull" the mounting arm up towards the bolt head. 100 foot*lbs on this bolt and I feel I have deformed the washer enough.
Someone give me some insight as what is going on here! Steeda???
Thanks!!
Dan
Danno-23 is offline
Old 05-15-2013, 09:10 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Moving you to the S197 Performance Handling section for pepes in the know
Jazzer
Jazzer The Cat is offline
Old 05-15-2013, 09:54 PM
Danno-23
Danno-23's Avatar
I don't get why this was moved to the V6 General Discussion Forum.
I cant even find this post from the main forum, but maybe my mouse is broken.
edit-
Ah never mind. Looks like there is a fair bit of stuff under this category
Danno-23 is offline
Old 05-16-2013, 07:14 AM
Jazzer The Cat
Retired Moderator
lol.... I might have mis-moved it, but is in the correct section now. Does your mouse look like this?
Old 05-16-2013, 10:16 AM
tj@steeda's Avatar
PM Sent.
Best Regards,
TJ
tj@steeda is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
09-24-2015 09:18 PM
Quick Reply: Steeda UCA S197
