NEW: Reische Performance 170deg Thermostat for all 86-93 Mustang 5.0L's NOW AVAILABLE
We're very excited to announce another awesome addition to the Reische Performance thermostat catalog. This one is specifically designed for the 86-93 Fox Body owners running the 5.0L engine.
ORDERS CAN BE PLACED HERE $49.99 SHIPPED in the lower 48
http://www.lethalperformance.com/sho...hermostat.html
This modified premium thermostat has a larger heat motor/spring assembly for more precise temperature control along with a heavy gauge chrome plated steel housing. 100% made in the USA. The NB-54 thermostat does not include a gasket due to the multitude of possible applications.
Beware of aftermarket companies who sell the same thermostat for all Ford modular engines. Reische Performance thermostats are the only ones designed to precisely fit each application, making them the best performing low temp units on the market! Whether you are using an aftermarket radiator or not, this thermostat will provide the best possible heat dissipation from your setup along with a faster warm up time and better cold weather performance than a 160° unit or a thermostat with holes drilled in the diaphragm. We believe the 170° opening temp is the ideal balance for high performance engines, providing high flow to your radiator by mid-180 temps while still providing good all season performance. With proper fan settings your coolant temps in cool weather will be in the 170s and in hot weather the 180s, giving those running high levels of timing and/or boost added protection against engine-damaging detonation as well as maximum power output.
All Reische Performance thermostats ship with coolant ratio, additive and fan setting recommendations.
