Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
ABS light
Old Nov 2, 2010 | 03:37 PM
theforsaken's Avatar
theforsaken
Default ABS light
So, i dropped the Mach 1. Ever since then, my ABS light randomly comes on and will stay on for a little while and then go off. i havent found that im doing anything when it happens. Just driving down the road and it will come on. Also, right after it comes on the traction control button light comes on (therefore my traction control is turned off)....as soon as the ABS light goes off....so does the trac light too....
i removed my wheels again to look at the ABS lines and try to look at the wheel sensors. Everything looks good to me.
Any ideas???
Old Nov 2, 2010 | 11:04 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
im still trying to figure it out, im thinking might be time to clean the sensors out.
Old Nov 3, 2010 | 09:35 AM
jwog666's Avatar
jwog666
get the codes pulled, they will tell you which sensor to focus your attention on.
Old Nov 3, 2010 | 12:59 PM
theforsaken
yea, id like to pull the codes...but its so damn random when the light comes on and it doesnt stay on for long.
Old Nov 3, 2010 | 06:55 PM
rygi23's Avatar
rygi23
sorry you're having the problem but I'm glad I'm not the only one.
Old Nov 3, 2010 | 07:39 PM
darkmach1's Avatar
darkmach1
Is your brake fluid low? Do you do hard braking? Check fuses 2.29 and 2.35 under that dash. Also, you can take it to a Ford dealer, I read once that they have an ABS code reader that hooks up to the OBDII.
Old Nov 4, 2010 | 09:34 AM
jwog666's Avatar
jwog666
if the light comes on the codes will be stored in the memory and can be pulled out later even if the light is off. they will eventually clear themselves, but that takes quite a few drive cycles.
Old Nov 4, 2010 | 01:39 PM
03_SH@KER's Avatar
03_SH@KER
i had the same problem now my abs light stays on all the time.. i haven't had the time to run the code yet.
Old Nov 6, 2010 | 12:15 AM
I G Joe's Avatar
I G Joe
sounds like when you dropped it you may have distrubed one of the sensors, may need to check all of them and make sure they are positioned correctly. the T/C most likely disables or enables itself when it either thinks one tire is spinning faster than the others. it probably does this to protect the system from over reacting to a faulty sensor.
Old Nov 10, 2010 | 09:40 AM
USMCrebel's Avatar
USMCrebel
I was just thinking it finally realized how useless it truly is and decided to give up b/c imma break traction anyways
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
