Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Please Help
Old Sep 24, 2016 | 11:19 AM
Big Al's 03's Avatar
Big Al's 03
Default Please Help
Hello Members,
My 03 Mach 1 was making thumping noise in back when I went over bumps
so I took it to the neighborhood repair shop to check it out, they told me
that the suspension on my Mach was changed to an independent suspension and that the problem was a worn out toe link,
well we have not been able to find the part because its an after market
toe link.
I hope the members here can give me some suggestions on finding the
part I need for my Mach cause the thumping noise is driving me nuts here are a couple of pics of the part... hope this helps.
Thanks in advance.... AL.
Old Sep 24, 2016 | 11:57 AM
jwog666's Avatar
jwog666
use this>>>>>>>>>>>>>>https://lmr.com/item/MM-IRSTR2/adjus...FYk6gQodqoAKSQ
you will have to change both of them but this will fit in place and with an alignment you will be good to go. FYI when looking for parts for the rear of your car search for parts for a 2003 mustang cobra, they came stock with rear independent suspension, and is the donor for swaps like what was done to your mach
Old Sep 24, 2016 | 12:13 PM
99GTvert's Avatar
99GTvert
is my username.
Any chance the 99/01 Cobra IRS is a little different? Juat curious if the IRS has a number stamped to indicate which year exactly it is or if (doubtful) its from another model.
Old Sep 24, 2016 | 12:19 PM
jwog666's Avatar
jwog666
i dont think it matters as most of the parts listed fit 99-04. they should all be the same
Old Sep 24, 2016 | 07:00 PM
Big Al's 03
Thanks for the info.......I knew someone here would have the answer
and your the Man jwog666.....Thanks again
Old Sep 24, 2016 | 11:42 PM
jwog666's Avatar
jwog666
Anytime
jwg45acp
Jul 23, 2017 02:54 PM
avengercap67500
Suspension
Mar 22, 2017 10:18 AM
Waferboy
Suspension
Aug 2, 2016 08:30 PM
Laguna02Stang
Jul 21, 2016 06:08 PM
