Massachusetts Regional Chapter Chapter President: Torch_Vert
TR-6060 Swap
Old Jul 10, 2012 | 07:16 PM
  #81
shad2009's Avatar
shad2009
let me know when you're gunna start
Old Jul 10, 2012 | 07:20 PM
  #82
Torch_Vert's Avatar
Torch_Vert
I have another obligation first thing Thurs. I'll be starting on the car around noon that day.
Old Jul 11, 2012 | 10:17 PM
  #83
Torch_Vert's Avatar
Torch_Vert
Tough day today, got everything out of the way of the transmission, shifter and wiring disconnected and all the bolts out, and the damn thing is stuck fast. Was out there until after 9pm trying to separate it from the engine.
Ah well, tomorrow is another day
Old Jul 14, 2012 | 10:44 AM
  #84
Torch_Vert's Avatar
Torch_Vert
The old transmission is finally out...
This is the pain in the butt that was holding up the whole works, one of the guide pins had welded itself so firmly to the transmission housing, that it actually pulled out of the engine block rather than pop loose from the bellhousing
Clutch was pretty ugly, NOT impressed with the Centerforce DF material on the flywheel side. Lots of hot spots and uneven wear, I think caused by the chunky uneven nature of the facing material used. All of a sudden pretty glad I'm going with a SPEC 3+ this time:
Pressure plate side wasn't too bad:
Grabbing some lunch, then back at it...
Old Jul 14, 2012 | 10:54 AM
  #85
S197GT07's Avatar
S197GT07
Wow, interesting spots on that flywheel. I would maybe contact them and ask WTF!
Old Jul 15, 2012 | 07:16 PM
  #86
Torch_Vert's Avatar
Torch_Vert
Weekend update: hung up by that stupid transmission dowel. It couldn't be wedged into the bellhousing tighter if it was actually welded in there.
Penetrating oil, heat and physical force all failed. Have to call around tomorrow and see if I can get a fresh dowel.
Used part of the downtime to install the new front lower arms (the FRPP GT500 ones) and to build up the new front strut/spring/bearing assemblies. Hoping I can get back to the transmission in a day or two.
Old Jul 17, 2012 | 12:31 PM
  #87
Torch_Vert's Avatar
Torch_Vert
Did one of the strut installs this morning. Didn't know the term "sweat pouring off" someone could be taken quite so literally... Me=
Old Jul 17, 2012 | 01:07 PM
  #88
S197GT07's Avatar
S197GT07
Yea it was a bit warm today!
Old Jul 17, 2012 | 01:31 PM
  #89
Torch_Vert's Avatar
Torch_Vert
Just a bit
Old Jul 19, 2012 | 06:48 PM
  #90
Torch_Vert's Avatar
Torch_Vert
Latest status update: suspension work is done, dowel to replace the one fused to the old transmission in hand, exhaust back from the welder after having the 2 relocated O2 bungs added, plus an extra bung for the wideband.
