Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Throttle linkage help
Old Aug 4, 2015 | 07:15 AM
teeeeg67's Avatar
teeeeg67
Default Throttle linkage help
Long on my way through my motor swap in my 67 coupe. I6 to 351w. The motor is in the car and I'm starting to get the odds and ends together. But I need help with the throttle linkage. Not sure what to do to make my linkage work or where to buy a kit to make my linkage work. Obviously with the I6 the throttle is on the passable side but with the small block it will go on the driver side. Any help would be appreciated
Old Aug 6, 2015 | 07:47 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Plenty of aftermarket suppliers out there...
-NPD (National Parts Depot)
-Mustang Unlimited
-J/C Pony parts
Those guys will have you covered.
Old Aug 7, 2015 | 07:48 AM
teeeeg67's Avatar
teeeeg67
I guess what my real question was not where to buy from. But as far as the linkage for a small block is it just the throttle pedal assembly and the rod between that and the carb?
Old Aug 9, 2015 | 08:03 AM
pascal's Avatar
pascal
Sorry, I didn't read you right...
You'll need everything from the firewall to the carb.
That includes the main linkage/rod which is much shorter for the V8 and also the correct short rod to connect from it to the carb.
Here's a diagram:
https://www.google.com/search?q=67+m...XmqNXhswdiM%3A
Note that it shows the difference between 2V and 4V carburetors...
Old Aug 12, 2015 | 12:01 AM
Stepman's Avatar
Stepman
In 69 the 351 uses a cable from pedal to carb. Maybe get a 69 pedal and go that route?
Old Aug 12, 2015 | 06:10 AM
teeeeg67's Avatar
teeeeg67
Thanks for the diagram and tanks also for the idea of of using a 69s set up bill look into it
Old Oct 20, 2015 | 07:35 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I know this is kind of and old thread but this needs to be posted up.
I did this to my 67 Fastback and man alive, I'm telling you what, it looks great, is absolutely butter smooth and cheap to put together. So if you're not going with a factory carburetor setup, I'd really suggest giving this a look.
http://www.fordmuscle.com/archives/2...kage/index.php
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
col2560
Sep 25, 2015 06:51 AM
JDWalton
Sep 24, 2015 08:47 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
