Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Find out engine year
Old Jun 4, 2020 | 12:41 PM
Bfree0306's Avatar
Bfree0306
Default Find out engine year
I bought a 1999 mustang get. The owner’s dad had done an engine swap and put a 4.6 cobra motor in it. He said it was a 1998-2004 motor. Is there a way I can find out the exact year?
Old Jun 12, 2020 | 08:09 AM
wbrockstar's Avatar
wbrockstar
I believe the main external difference between the 4.6 GT & 4.6 Cobra engine is the GT uses a 4.6 SOHC 2 valves per cylinder engine with a cast iron block while the Cobra uses a 4.6 DOHC 4 valves per cylinder engine with a aluminum block,so if your block is cast iron,its not a Cobra engine.96-01 Cobras used aluminum block then switched to cast iron in 03-04.The following link will help you inspect your engine to id its year.Quite a bit of info to look over here.
https://fordcobraengines.com/ford-mo...r-differences/
Tony Silva
Mar 21, 2017 01:49 PM
dons98stang
Jul 20, 2011 07:36 AM
Kats96gt
Jun 11, 2008 02:29 PM
Feng Houzi
Sep 4, 2007 09:33 AM
redstanggt
Mar 25, 2004 09:12 PM
