Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
what timing do i run with 75 s
Old Feb 15, 2004 | 08:04 PM
robbie's Avatar
robbie
Default what timing do i run with 75 s
ill be running race fuel 110 and i have a stock fuel system</P>
Old Feb 16, 2004 | 01:02 AM
stang574's Avatar
stang574
There’s no magic number to set base timing at since every engine is different. I know guys who run at 14 degrees and I know guys who run 9 degrees. The key is to avoid detonation. If your running fine with out detonation then back your timing up 1-2 degrees and you'll be safe. Especially with 110 petrol.
Old Feb 18, 2004 | 04:04 AM
Quik's Avatar
Quik
Default RE: what timing do i run with 75 s
for every 50 you do retard timing 2 degrees minimum
Old Feb 21, 2004 | 10:57 PM
vfast's Avatar
vfast
I ♥ Acer
why are you wasting your $$$$ on 110?... 10 degree on a 50-75 shot using 93
djbigskrilla
Sep 20, 2022 01:04 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
gus_vb
Aug 29, 2015 11:35 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
timeformiller44
Aug 26, 2015 12:03 PM
