Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous System Installation???
Old May 9, 2006 | 06:02 PM
Blade660's Avatar
Blade660
Default Nitrous System Installation???
Can anyone tell me just how hard it is to install a nitrous system in a stang, about what it will cost and how long it would take to install if you had everything there waiting to go in?
Old May 9, 2006 | 06:18 PM
redmustang83596's Avatar
redmustang83596
Default RE: Nitrous System Installation???
Depends on the kit you want, and the year mustang your putting it in. Its not a very hard job, it just depends how much you want to spray. If it is dry, itll take like an hour at most. If its a wet kit, it'll take a little longer, maybe hour and a half - two hours, if its just a nozzle. If its a plate kit, well itll take a lot longer because you'd have to pull the upper intake off. What kit do you want and what year mustang do youhave?
Old May 9, 2006 | 06:38 PM
WLingle92lx's Avatar
WLingle92lx
Dry kits range from $480 - $520.00
Wet kits range from $560 - $1,000.00
If it is your first kit it will take no less than 3 hours if you do a neat job and keep everything clean.
Dry kits take around 2-3 hours to install
Wet kits take around 3-4 hours to install
Old May 9, 2006 | 06:49 PM
nitrous_bob's Avatar
nitrous_bob
ORIGINAL: WLingle92lx
yes thats a little more accurate. no way can you do it in 1 hour.
most shops charge about $300-$500 for the install , i would never pay for it.
it's very ez. you need to do some minor wiring (tap a hot power X 2 , and ground a few pieces)
mount the bottle , put the selonoids together (use paste , not tape)
expect 4 hours total since your first time.
Granatelli Sales
Jan 20, 2020 12:34 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
kawiguy827
Sep 1, 2015 07:09 PM
