Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
intercooler question
Old Jul 13, 2006 | 08:12 PM
  #21
QUIKSVT's Avatar
QUIKSVT
Default RE: intercooler question
I just want to clarify here. When Nanaki says you'll pop the motor if the boost cooler malfunctions thats ONLY if you have upped the boost, or added timing to take advantage of the added octane and lower charge temps. If your running low boost already, with no methanol, and you throw methanol on it and don't add timing or boost your in no danger of damaging anything should it fail to operate properly.
I personally wouldn't tune more aggressively based on the trust that the boost cooler is going to do its job EVERY time. I would just be happy with the lower charge temps which should yield good power gains alone.
Old Jul 13, 2006 | 08:46 PM
  #22
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: QUIKSVT
what's the point of adding the methanol if you don't plan on taking advantage of the ability to run more timing? that's the whole point of going with a water/meth intercooler. that just seems like a waste of $400+ to me.
Old Aug 12, 2006 | 04:24 PM
  #23
BicketyBam's Avatar
BicketyBam
ORIGINAL: QUIKSVT
If you don't tune it to compensate for the added fuel (methanol) it's going to run pig rich at WOT. You'll lose hp.
I have a dynojet wideband a/f gauge. Whenever I am into it, I keep an eye on it. If my meth kits stops functioning, it will go real lean real quick.
Old Aug 12, 2006 | 08:23 PM
  #24
99roushgt's Avatar
99roushgt
i got a snow performance methanol kit for sale with the progressive controller im going to just go with some nitrous instead if your interested in it pm me or something
Dokilar
15
Oct 16, 2015 08:13 PM
Bokeo
Oct 10, 2015 08:28 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
