Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Fuel for Nitrous Question!!!!!!!
Old Mar 21, 2007 | 02:22 AM
ZW99GT's Avatar
ZW99GT
Default Fuel for Nitrous Question!!!!!!!
Well I got a tune for the 100 shot b/c of my crappy, stock drivetrain. I have a built bottom end, so hurting the engine is not really a concern at this point.
At the dyno, the tuner made a graph during a pull, and it shows my SVT Focus fuel pump is working at 83% on the numbers in my sig.
How much more fuel is needed by jumping up to the 150 shot? For all you guys, thats going from a 28 fuel jet to a 35. Do you think my pump would be ok? I will probably run race gas on 1 degree timing retard.
Old Mar 21, 2007 | 02:42 AM
bryanec's Avatar
bryanec
Default RE: Fuel for Nitrous Question!!!!!!!
My svt pump handles the .035 jet very good. On the dyno my air fuel stayed at a constant 12.1 at 43psi , no spikes or fluctuations (we didnt feel a need to log any duty cycles). I am only running the .057 jet on the n2o side (still debating on using the .062 on the stock rods). I am pulling 6 degrees out of my na tune for 125 shot. You should be fine with a 104/93 mix, I love the smell.
[align=left] [/align]
Old Mar 21, 2007 | 03:42 AM
ZW99GT's Avatar
ZW99GT
ORIGINAL: bryanec
So you think the Focus pump will be ok on 475rwhp? Thats what I like to hear!!!!! I'm probably gonna pull an extra 2 degrees out of my 100shot tune, and run 93/110 mix just incase.
THANKS
Old Mar 21, 2007 | 05:31 PM
ZW99GT's Avatar
ZW99GT
Anyone else please?
Old Mar 21, 2007 | 06:02 PM
Frebius's Avatar
Frebius
You should be fine. If you are worried about it get some jets for a 125 shot and try it first on the Dyno if your car starts to run lean then you should probably getting a better pump. Just try it and see what happends.
Old Mar 21, 2007 | 07:50 PM
code3GT's Avatar
code3GT
Mustang Nazi
You should be fine, but if you're worried...get a boost a pump.
Old Mar 21, 2007 | 10:42 PM
ZW99GT's Avatar
ZW99GT
I'm not worried anymore. I was just checking to see if I need to be worried. lol.
150 it is........
Tivo304
Aug 28, 2023 12:19 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
