Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Zex window switch - green wire?
Old Mar 22, 2007 | 12:29 PM
Timber's Avatar
Timber
Default Zex window switch - green wire?
Where do I splice this one in to get a tach signal?
Thanks.
Old Mar 22, 2007 | 05:29 PM
hitsman10's Avatar
hitsman10
Default RE: Zex window switch - green wire?
i had a post on this last week.
https://mustangforums.com/m_2897415/tm.htm
ask zw99gt to find out were it goes. Also not 100% positive but i think if u get a tach adapter ( i have a shift light) you can use that
but i have not finished my install yet, bc of that damn tach signal which i alsostill not clear were it goes
Old Mar 22, 2007 | 10:07 PM
Timber's Avatar
Timber
I ended up called Zex tech support. You can hook it up to any coil. Each coil has a red wire and another wire. Hook it up to the other wire. I hooked it up to coil 2, green wire/white stripe. I'm not done with mine yet either, I've got the wiring in the car to do tomorrow. Then we'll see if it all works.
unit91
Sep 15, 2015 09:53 AM
PNYXPRESS
Sep 14, 2015 09:50 PM
Wombatnation
Sep 13, 2015 09:16 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
