Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Intake temperature sensor before or after procharger
Old Mar 10, 2008 | 06:01 PM
RED2000's Avatar
RED2000
Default Intake temperature sensor before or after procharger
Im just about done with my setup and about to tune it. I called procharger and they said that the intake temperature sensor goes before the supercharger. Is this right? It dosent seem to make any sense...
Thanks
Old Mar 10, 2008 | 07:01 PM
Obsequious1's Avatar
Obsequious1
Default RE: Intake temperature sensor before or after procharger
The sensor goes on the intake tube. You can't see mine because of the angle. You can also mount it on the steel tube.
Old Mar 10, 2008 | 08:09 PM
RED2000's Avatar
RED2000
So before the procharger, right after the air filter? Wont it be reading the temp before it goes through the procharger, so it would be a different temp? Wouldent it be more accurate after the air is cooled by the intercooler?
Thanks
Old Mar 11, 2008 | 07:08 AM
Obsequious1
Mount the sensor on the 45 degree rubber elbow connecting your intake tube to the throttle body. I don't know why Procharger say to mount it before the charger. You need to know if the charge is too hot right? Suppose you run over a plastic bag and it gets stuck in front of your intercooler. You wouldn't be able to tell that your air charge was hotter than hell with the sensor before the charger. You can also be creative and mount it in the intake tube, like where the sensor would be on a BBK CAI. My 03 came with the sensor built in my MAF(6 prong). SCT sells a meter w/ the sensor built in it and I think its the 1999 lightningMAF thats the same way too. When I upgraded my MAF to a 90mm(4 prong), it didn't have the sensor in it soI had to buy a sensor and wire it up into my intake tube.
Old Mar 11, 2008 | 09:15 AM
RED2000's Avatar
RED2000
Thanks for the help
Jb145700
Aug 21, 2022 06:37 AM
articman
Jun 21, 2018 11:45 PM
Vrooom
Feb 21, 2016 05:25 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
