Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Need Help With S/C
Old Jun 27, 2005 | 03:22 PM
ProjectStang's Avatar
ProjectStang
Default Need Help With S/C
I have a 98 GT auto with BBK headers,mac x pipe, flowmaster mufflers, and 3.73 gear (not yet installed). I just bought a used paxton S/C. The kit has the head unit (sn93), the mounting bracket, the Fmu, piping, pulleys, and belt. What else will i need to make the car run right i would like to upgrade the MAF and injectors to 40lbs. I think the pully that is on it is set at like 6-7 psi. I would like to run 9-10 psi in the future. Any help would be great this is my first S/C so i am in the dark a little.
Old Jun 27, 2005 | 03:27 PM
MarcusM's Avatar
MarcusM
Default RE: Need Help With S/C
I would def. suggest new injectors, as well as a fuel pump. You are getting a ton more air than stock, and the fuel system can't hold up with that... With my vortech the kit came with the fuel pump, you can find them on Ebay fairly cheap.
Old Jun 27, 2005 | 03:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
You'll need the kit w/ brackets to fit your year 4.6, a chip/tuner, an fmu, fuel pump, and injectors. 30#'ers will be more than enough for your needs.
Old Jun 27, 2005 | 03:41 PM
ProjectStang
thanks For the help with the new injectors do i have to get a maf or wil the chip/tuner take care of that? What tuner to you suggest?
thanks
Old Jun 27, 2005 | 04:24 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
you can either get a maf calibrated for your injectors or fix it with a tune. The car won't run right or at all unless you do so. Matter of fact, try not to drive the car at all with out a dyno tune if you can help it.
Old Jun 27, 2005 | 04:34 PM
ProjectStang
I am not in any rush i am going to wait till i get every thing an then take it strait to have it tuned when i am done. If i am running 6-7 psi can i just get an inline fuel pump and wait on the injectors or so i still need them? By the way the car has 48000 miles on it.
Old Jun 27, 2005 | 08:08 PM
mustang_montana's Avatar
mustang_montana
not to hijack ur thread, but if you use an intank fuel pump (255lph) is that just as good as an inline...for a sc application?
Old Jun 27, 2005 | 10:18 PM
ProjectStang
With the vortech and the other inline pumps are they in addition to the intank or do they replace the intake?
Soldier GT
Aug 12, 2015 03:46 PM
94Cbra
Oct 8, 2004 07:00 AM
RollinThunder
Sep 16, 2004 01:42 PM
iiiGTiii
Aug 26, 2004 03:07 PM
RollinThunder
May 17, 2004 01:06 AM
