Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Procharger
Old 02-08-2006, 03:30 PM
96mod289
96mod289's Avatar
Default Procharger
i was wonder if 10psi would be safe on a 96gt with a procharger intercooled. also will i need higher than 91-93 octane .
96mod289 is offline
Old 02-08-2006, 03:33 PM
FoxRod
FoxRod's Avatar
Default RE: Procharger
Yes you'll need higher octane. What fuel and ignition setup are you runnin?
FoxRod is offline
Old 02-08-2006, 03:35 PM
96mod289
96mod289's Avatar
well i was looking into buying a kit and i was wondering if 10psi was too much or what? with 8psi i could run on pump gas right?
96mod289 is offline
Old 02-08-2006, 03:39 PM
FoxRod
FoxRod's Avatar
oh man I'm sorry I read your first post wrong. You'll still be able to use pump at 10 psi. I'm sorry I read it as "will I have to go from 89 to 93" My bad.
FoxRod is offline
Old 02-08-2006, 03:40 PM
FoxRod
FoxRod's Avatar
93 octane would be fine. Do you have any other upgrades or is this going to be your first mod?
FoxRod is offline
Old 02-08-2006, 03:46 PM
96mod289
96mod289's Avatar
i have exhast and that is about it. but do you know if i go with a 10psi set upwill that be safe on the crank below the 425hp limit
96mod289 is offline
Old 02-08-2006, 04:46 PM
FoxRod
FoxRod's Avatar
Yeah that should be no problem. I definately would see about an upgraded ignition system and make sure the procharger comes with a fuel management system of some sort. If not look into getting one of those as well. Detonation is not your friend.
FoxRod is offline
Old 02-08-2006, 07:04 PM
nanaki
Retired MF Moderator
nanaki's Avatar
when you get it tuned, they'll tell you what octane you gotta use. which is usually 91+.
nanaki is offline
articman
06-21-2018 11:45 PM
Granatelli Sales
03-21-2016 06:16 PM
Dragonus18
09-09-2015 01:21 AM
Black_GT_02
08-20-2015 01:26 PM
RedStangGT2000
05-15-2004 05:55 PM
Quick Reply: Procharger
