18" polished wheels
i just upgraded to the 18" polished wheels that come with the upgraded stangs and the chrome is literally like a millimeter from the caliper, do i need wheel spacers and where can i find them? p.s i have a v6 stang w/ pony package just figured id post here because i figured most people with these wheels have gts
If I had to guess I would say the v6 cars have a slightly different offset due to the rotor hats, but the pony package cars come with 17" bullit wheels so who knows.
without seeing it it's hard to make any reasonable assumptions, but if it's got you worried you can run 1/4 inch spacers if it's a street car. Track guys should avoid running spacers due to the extra load on the studs, but for you they wouldn't be a problem.
Absolutely no warranty implied, liability extended or risk assumed, yada, yada, yada
I have the American Muscle 18" DD Bullitts. When I first put them on the car I was really worried, just like you are. The spokes are literally a couple MMs from the caliper. That was 8 months ago.After about3000 miles, including many laps on AutoX courses (before I bought some light weight 17s) I've had zero issues.
.I have the American Muscle 18" DD Bullitts. When I first put them on the car I was really worried, just like you are. The spokes are literally a couple MMs from the caliper. That was 8 months ago.After about3000 miles, including many laps on AutoX courses (before I bought some light weight 17s) I've had zero issues.
My Brembos are quite close, but figure it is less than 1/4" (never measured), does the caliper have scratches?I agree with Radio, run 1/4" spacers and should be fine. Good question, what is the minimum safe number of threads be for a lug? I would figure 3/4" is about as minimum I would like to see. Anyone know?
Jazzer
Jazzer
ORIGINAL: Jazzer The Cat
Jazzer
Jazzer
http://www.tribology-abc.com/calculators/stripping.htm
As a practical matter, most places will accept full form thread engagement equal to the stud diameter. Note that OE studs in particular may not be full-form out to the very end, so there may be a requirement that "x" number of threads be visible outside the lug nut or that you might have to remove a nut to demonstrate adequate length.
http://www.hotrod.com/techarticles/n...ets/index.html
Norm
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
