Track tire pressure for stock radials?
Will dropping a few pounds of pressure in the stock Pirelli 255/35/17's give me slightly better traction at launch? I'm taking her to the track tonight and wondering what pressure I should be running in the front and rear to give me any better traction, if any, in my 60 ft. time. Thanks
RE: Track tire pressure for stock radials?
WhenI ran the stock tires at the track, I'd bring the rears to about 27 psi, which is a minor drop in pressure. Personal best 60' on the stock tires is a 1.819.
when I went to the track I dropped my PSI in the rears to 25, left my fronts at 35.. didn't even see if a higher PSI in the rears would have made a difference, first run i had already dropped it.. in hindsight i should have had atleast a couple runs at stock psi then lowered it.
I did this based on someones recent post on S/S about how he ran 35psi 3x then dropped it down to 25psi and got a much better 60' with the same launch technique he used before.
Generally somewhere between 25-28 psi will work depending on track and temp and how much you clean the tires.
Carefull on cleaning the tires as all-seasons dont take well to excessive heat.
I may do a short stationary burnout, rolling burnout, or barely clean the tires depending on track temp.
My best 60 is 1.859 on 25 psi (cold). Scott C did 1.841 on 28 psi (100% stock car) and AmericanSpeeds 1.819 on 27 psi may be a record with stock 3.55 gears. I know a couple of 1.79 on 25 psi but thats with 4.10 gears.
