Tires!
Old Oct 16, 2008 | 06:31 PM
sailing220's Avatar
sailing220
Default Tires!
What is the widest tire I can put on the stock 17" rims?
Saleen + 4.10s = no traction...
Thanks.
Old Oct 16, 2008 | 06:47 PM
Nuke's Avatar
Nuke
Depends on the width. Check the SVT wheels on their website or on tirerack for the specs. Probably 8.5". Max width would depend on the tire manufacturer but probably not much beyond 275's, if that.
Old Oct 16, 2008 | 08:38 PM
Stkjock's Avatar
Stkjock
Retired Mod
stock 05 17" are 8" wide, 275/40/17s about as wide as you can go, and that's a bit of a push
Old Oct 17, 2008 | 02:17 AM
sailing220's Avatar
sailing220
Thanks, good info.
Old Oct 20, 2008 | 09:17 PM
dlarge122878's Avatar
dlarge122878
You can put a 275/50/17 on the stock 17x8's but the tire choices aren't in your favor. I just recently went through this same problem. Your pretty much forced to buy aftermarket wheels that are wider so you can afford a good wide tire!
Old Oct 20, 2008 | 09:22 PM
Texotic's Avatar
Texotic
i wouldn't go wider than a 275. get some wider wheels.
Old Oct 21, 2008 | 08:04 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
A 275 is going to give you quite a bulge over the wheel as a 255 is a much better fit for an 8.5", IMO.
I am with others and recommend getting a set of 18"x10"s out back and putting some quality tires back there.
Jazzer
Old Oct 21, 2008 | 07:08 PM
jayel579's Avatar
jayel579
I run 275/40-17s for my auto-X tires. I put have on 17x8 size rims. That size is going to give you the widest variety of tires available. As soon as you start going into other sizes tire types get hard to come by.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
