Panhard Bar
Old Nov 21, 2008 | 08:53 PM
  #41
07musclemustang's Avatar
07musclemustang
NORM I too liked the CHE untill i found they are non greaseable. Correct me if im wrong but its not greaseable would there not require a deteriation of some part to create a lube between the parts? would you really think a no maontanecnce part is really best? it just seems friction needs some modifier? Input???
Old Nov 26, 2008 | 04:01 PM
  #42
tx_zstang's Avatar
tx_zstang
Just to toss in a 'simplicity' comment, if you are not planning on lowering the car and just want elimination of wheel hop, the easiest and simplest and least expensive simple fix is to get some fixed-length lca's, and not changing the uca nor any panhard peices.
Beyond that, the range of possibilities is obviously immense, and will vary by your needs (daily driver, track, drag strip, etc.). Getting the property suspension geomety is very important for optimum handking for your desired driving conditions. (..and I'm still learning, too, so keep them posts coming!..)
Old Nov 26, 2008 | 08:13 PM
  #43
Norm Peterson's Avatar
Norm Peterson
My own understanding is that Delrin on steel is a significantly lower friction pairing than polyurethane on steel, meaning that there is much less need for supplemental lubrication in the first place.
Norm
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
