Adjustable PHB needed??
Old Jan 10, 2009 | 09:27 PM
houstonnw's Avatar
houstonnw
Originally Posted by Jazzer The Cat
Whatever YOU call acceptable is OK with us
If you don't rub, and looks OK to you.... leave it alone.
Jazzer
I agree. I'm planning to start doing NASA Time Trials this year and replacing the stock panhard bar costs two points and I don't think it is worth it.
Old Jan 11, 2009 | 07:31 AM
Sleeper_08's Avatar
Sleeper_08
Very interesting that they 'penalize' you 2 points for changing the PHB. From my knowlledge the 2 main benfits from changing the PHB are;
1) an adj PHB allows you to set the axle perfectly in the center of the car
2) the bushings can be changed and thus it could have two rod ends (heim joints)
It would be interesting to know how much of the 2 points they 'assign' to each of these.
Old Jan 11, 2009 | 09:42 AM
s197shockwave's Avatar
s197shockwave
hey if it does not rub and you can't tell, forget the p.h.b.. my driver tire did rub on dips so i NEEDED the p.h.b..
Old Jan 11, 2009 | 02:07 PM
houstonnw's Avatar
houstonnw
Here are the two rules:
18) Replace or modify an OEM panhard rod or Watt’s link +2
25) Metallic replacement suspension bushings (Heim joints/spherical joints) +3 (except for
pillow ball camber plate joints, sway bar end links already assessed points in 6) above, and
upper contol arm spindle/knuckle joints already assessed points in 7) above)
I thought that the 2 points would also get you spherical joints like the sway bars - nope.
Old Jan 11, 2009 | 08:42 PM
Sleeper_08's Avatar
Sleeper_08
Interesting that they think it is that important. Thanks for providing the details from the rules.
Old Jan 16, 2009 | 10:28 PM
rford426's Avatar
rford426
so are they worth it or not?
Old Jan 16, 2009 | 10:33 PM
howarmat's Avatar
howarmat
s197 Junkie
lowered 2 inch has to be out more than just 1/4 inch. The physics say so!
Old Jan 18, 2009 | 08:22 PM
s197shockwave
aligns the rear, as far as performance i have noticed nothing.
Old Jan 18, 2009 | 09:00 PM
Texotic's Avatar
Texotic
Wouldn't that have more to do with Geometry than Physics? Either way, it has to be more than 1/4" off.
Old Jan 19, 2009 | 06:11 AM
Norm Peterson's Avatar
Norm Peterson
The PHB is 40 inches or so in length. Are you trying to tell me that on your car the PHB chassis end is 4.5" higher than the axle end? Is the car up on a chassis lift with the axle at full droop?
Norm
squishbang
Dec 4, 2015 02:29 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
StangfireGT
Aug 20, 2015 08:51 AM
defarmer
Aug 13, 2015 06:40 AM
ponyride00
Aug 12, 2015 01:57 PM
