anti-squat?
Some places - http://www.s197performance.com/CHE-P...ets-_p_15.html
..refer to LCA relocation brackets as anti-squat brackets. I had other ideas about these - like eliminating wheel hop.
Regardless, I don't like how much my car squats from 1st to 2nd or from 2nd to 3rd. These things really prevent the car from squatting?
i just picked up a set of CHE anti squat brackets and should get them in before my next track day april 3rd. i'll let you know if it helps my 60'
This article is a pretty good discussion of how LCA Relocation Brackets work http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
For a detailed discussion of Anti Squat you will need a reply from Norm unless you can find his previous postings by searching this Forum.
"Anti-squat" is a rear suspension geometry thing that causes the rear tires to be planted more rapidly than weight transfer through the springs and shocks can make the same thing happen. These "relocation brackets" change the rear suspension geometry in a way that increases the anti-squat, so you get a bigger chunk of the more immediate part of "planting the rear tires". This may help eliminate wheel hop, although wheel hop is also related to control arm bushings.
about shocks - firm in the rear helps prevent squat, and soft up front lets the nose rise a little more freely (at least until the front suspensions top out and/or you've pulled one or both front tires). Better than doing nothing and still good for fine tuning, but not as effective as getting the geometry closer to right with anti-squat/relo brackets.
Norm
dkersten
Sep 7, 2010 01:56 AM
armycook1981
Jul 11, 2006 01:49 PM
