Suspension Upgrades
Old Jul 19, 2009 | 06:47 PM
deekum1627's Avatar
deekum1627
nice thanks for that sleeper its help me alot
Old Aug 1, 2009 | 03:01 PM
2Gils's Avatar
2Gils
Originally Posted by Sam Strano
You must define what you want to change about how the car drives in order to pick the best parts for the job.
Personally, and you will find agreement from anyone else who has been down this road, I find the stock dampers (shocks and struts) to be the biggest issue. The car won't take a set, feels "big", rear jumps around... and while dampers don't cut roll--they do cut roll rate, a LOT. Enough that it's very common for people to tell me their cars "don't roll" after installation of the better dampers. Funny because the car rolls as much--just not nearly as fast and so it feels like much, much less.
Bars cut roll. Springs cut roll and some pitch. Springs are damped by shocks, and the stock shocks aren't great to start with. Doing springs without dampers isn't the smartest move unless you truly only care about looks and could care less about ride, stability, or how easy and confidence inspiring the car is to drive at more than normal pace on a highway.
Shocks, springs and bars are the big three as far as the suspension goes. Each does it's own job, but also interact with the others.
Hi Sam, you metion rear end jumps around. Mine does just that. If I take and on-ramp corner that has a crack or buckle in it, the rear end seems to lose contact and skip sideways some. I am fine with the handling of the car but this is annoying. Is this the dampners? Thanks!
Old Aug 3, 2009 | 11:58 AM
Sam Strano's Avatar
Sam Strano
Former Sponsor
That's the starting point... You'd be amazed what a decent set of shocks would do. If you want non-adjustable, Koni STR.T's would be the recommendation I have. If you want adjustables then Koni Sports... rears are available, but it's about 2 months for fronts at this time. Other options exist too, which I'd be happy to discuss with you if you'd like.
Old Aug 5, 2009 | 07:22 PM
2Gils's Avatar
2Gils
Thanks Sam, I will check them out.
PaulH2
20
Jan 31, 2016 09:48 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
