Anyway to adjust steering sensitivity
Old 09-07-2009, 10:26 PM
Skarkull
Skarkull's Avatar
Originally Posted by Sleeper_08
Sorry if I missed it but which springs do you have in your car?
FRPP M-5300's I think that is the part number, the 1.5" drops from Ford.
Skarkull is offline
Old 09-08-2009, 08:30 AM
Norm Peterson
Norm Peterson's Avatar
Originally Posted by Blair
Toe out or zero toe can sometimes make the car twitchy or darty like that at high speeds. Toe out is great for transitions and turn in, but not so much for high speed straight line stability. I'd try running maybe 1-1.5 degrees total toe in. That would increase straight line stability, but you'd lose some turn in response.
Blair
Way, way too much.
1° total toe is almost 1/2" in traditional US domestic toe measurements. You shouldn't need any more than 1/8" (0.25°), and IIRC the spec is 0.1°, ±0.2° which suggests that 0.3° is a reasonable upper limit before you start looking at something else being the culprit.
Skar - this is not a front roll center issue, so the first two items on your list won't directly address what's going on. Indirectly, they might, through the bumpsteer effects being changed with them. I don't know if they'd make your situation better or worse, though, only that it would be "different".
Lowering may have reduced front aero lift, which would translate to greater steering response (and these cars seem to be pretty responsive to the initial steering input as it is). If this is the case, you'll probably adapt to it.
Zero to 0.1° toe may not be enough at those speeds. As far as camber goes, be careful. Depending perhaps on the specific tires you're running up front, camber that's less negative could actually increase the initial response (keeping in mind that the roll that works against the static negative camber setting does not occur instantaneously).
Norm
Norm Peterson is offline
cr620
10-03-2022 10:18 PM
CS2007
06-25-2019 09:45 PM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
winner99
09-30-2015 07:04 PM
Quick Reply: Anyway to adjust steering sensitivity
