lowering springs
Old Nov 7, 2009 | 12:13 PM
  #21
3.73-11's Avatar
3.73-11
I used Tein S-Tech springs just about a 2" drop in the rear and 1" in front I really like it as the car is almost completely level now front&back
Old Nov 7, 2009 | 03:50 PM
  #22
BL00DSH0T's Avatar
BL00DSH0T
Originally Posted by nemosgt
The FRPP suspension parts may come loose if they re-use the original fasteners. They are one-time use as they deform. Either use new Ford fasteners or use locktite. My FRPP front roll bar came loose after install by Ford dealer. Then I did some research on the matter and found this out.
Cheers.
The FRPP are no different than any other aftermarket parts. There are a few nuts/bolts that are one time use only per manufacturers specs, but not all follow them. I do on certain things. Suspension I have have yet to see a bolt that is one time use or one that has failed when torqued properly.
As far as your roll bar coming loose how do you know for sure your dealer torqued it to specs?
Old Nov 7, 2009 | 04:28 PM
  #23
tenwatt's Avatar
tenwatt
Default Ford Racing Springs
Here are some pics of my '10 GT with the Ford Racing springs installed. They maintain a slightly higher rear end like the stock mustang.
Old Nov 7, 2009 | 06:15 PM
  #24
notsofast's Avatar
notsofast
If you lower it just don't forget to have front end aligned - not so much for camber (which will change a little more neg.) but for toe correction.
Old Nov 8, 2009 | 01:08 AM
  #25
xspsi's Avatar
xspsi
I like the rims! Who makes them and what are the specs?
Old Nov 8, 2009 | 06:26 AM
  #26
tenwatt's Avatar
tenwatt
thank you. they are HD Signature Autobahn, black machined. I believe the rear are 20"x10s and the front are 20"x9".
here is a link to them
I'm going to have the stock 18" polished aluminums put on in few weeks for winter. I'll post some pics to show how the springs look with those as well.
Old Nov 8, 2009 | 11:54 AM
  #27
nemosgt's Avatar
nemosgt
You may be right. I don't know. Just what I was told.
Suppose it's a good idea to check every thing periodically in either case.
Cheers.
lincolnshibuya
Jul 5, 2020 03:05 AM
CS2007
Jun 25, 2019 09:45 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
