View Poll Results: WHAT VISCOSITY OIL ARE YOU RUNNING FOR ROAD COURSE DE APPLICATION ??
5W 20
45.00%
5W 30
40.00%
10w 30
5.00%
10w 40
5.00%
other
5.00%
Voters: 20. You may not vote on this poll
Oil viscosity ?
Old Dec 1, 2009 | 05:10 PM
14901490's Avatar
14901490
Default Oil viscosity ?
I am posting this here because I d like input from those who use their cars on road courses.
My typical DE is four 30 minute sessions on track - for 2-3 day events.
My question is - Do you stay with Fords recommendation of 5/20 weight or use something else?
Thx.
Old Dec 1, 2009 | 05:45 PM
RodeoFlyer's Avatar
RodeoFlyer
I run 5w30, per a former FoMoCo engineer that worked on the 4.6 3v. He can't divulge much, but said he would NEVER run anything less than 30w in a modular engine. The 5w20 is simply to meet CAFE requirements.
I change mine after every event.
Old Dec 1, 2009 | 06:07 PM
14901490's Avatar
14901490
Thanks, my inclination was 30 would be better
What is "CAFE requirements" ?? EPA stuff ?
Old Dec 1, 2009 | 06:26 PM
RodeoFlyer's Avatar
RodeoFlyer
Federal fuel efficiency standards.
Old Dec 1, 2009 | 07:59 PM
Argonaut's Avatar
Argonaut
Agree with Matt, run 30W. I did some testing a while back, sent samples into Blackstone lab. Mobil 1 5W30 after 5 track days was perfect, zero abnormal wear. I don't race like Matt does but for a DE guy I'm satisfied you can get 5 or 6 days per oil change.
Old Dec 1, 2009 | 08:59 PM
zero2sixd's Avatar
zero2sixd
I use 5w30 based off of the same information Rodeo posted (there is a long thread on this topic at corner carvers). I'm too scared to leave it in for more than one event, even though the Blackstone tests don't show any significant wear metals. It's not that expensive and the oil is easy to change on this car.
Old Dec 2, 2009 | 02:49 PM
jayel579's Avatar
jayel579
I run 5w30 as well. Oil is the life blood of your car and like zero2sixd said it is cheap and easy enough to change out. I autocross way more then track my car but I still put higher demands on the motor then usual street driving.
Old Dec 2, 2009 | 09:48 PM
Import_Slaya's Avatar
Import_Slaya
Mobil 1 30w or 40w depending on what is in stock the weekend before a driver event. I sent a sample of the Motorcraft 5w-20 to Blackstone--otherwise fresh oil with only a single HDPE weekend and it had sheared to lighter than a 20w. Between that data point and the cc.com thread, I made the decision to never go below a 30w.
Old Dec 3, 2009 | 10:21 PM
Red06's Avatar
Red06
Mobil 1 5W30 here.
Old Dec 4, 2009 | 09:27 AM
14901490's Avatar
14901490
Thanks all- sold on the 5 w 30 WEIGHT. However ..
Not sure i want to bring this up But -I personally am planning to switch FROM any & all Mobil products TO Companies who do not import Middle Eastern oil- such as BP Castrol Pennzoil Kwik fill Sunoco.Something to think about....
