Hawk HP+ and HPS
Old Feb 19, 2010 | 05:02 PM
gmoran1469's Avatar
gmoran1469
Default Hawk HP+ and HPS
I just got my HP+'s installed on the front and HPS's on the back. I am assuming these things are supposed to be this loud. High pitched squeeling when stopping on the street right (only the HP+'s, not the HPS it seems)?
So basically, I need to get a set of HPS's for the front to be able to swap out the fronts for track days but keep the back since it's a bit more trouble to change the back brakes what with that stupid screw-in caliper and all, right?
Old Feb 19, 2010 | 05:43 PM
JimC's Avatar
Super Moderator
I don't have any squealing from my Hawk pads - did you bed them in properly?
Edit: now that I re-read your post, I have the HPS all the way around so it may be just the HP+ for your front brakes.
Old Feb 19, 2010 | 07:40 PM
Sleeper_08's Avatar
Sleeper_08
Check out this thread starting at post #11
http://s197forum.com/forum/showthrea...821#post427821
My HP Plus pads also squealed on the street. Trying Carbotech this year.
Old Feb 19, 2010 | 08:48 PM
gmoran1469's Avatar
gmoran1469
That would make sense, the pad would bite harder into a hot rotor/pad than it would a could rotor/pad which would account for the squeeling, I did bed them in as properly as I could on the street. The directions called for bringing it up to medium speed, which I ran 45 Mph for, then track speeds, I had to hop on the interstate and push at least 3 digits so I did that right before the exit, hopped off and pulled into the gas station to let it sit. I noticed no squeeling on the way back after a warm up and some test braking once everything got hot with decent braking, only with hard braking did I notice squeels, then when it's cold it squeels no matter what pretty much.
Old Feb 19, 2010 | 10:04 PM
dvs4.6's Avatar
dvs4.6
i have to agree with JIMC, i have the exact set up, and have zero squeling on the street only on the track under extreme braking.
dochawk
Aug 25, 2015 08:25 AM
Voodoo
Jan 1, 2006 03:36 PM
LazrRd00GT
Jul 3, 2005 08:48 AM
DukeU03
Apr 13, 2005 08:30 PM
