2011 GT F stock question
A friend of mine just bought a 2011 5.0 with Brembo Package and 3.73's. The question I have is, can you legally downsize to an 18" wheel with the same width and offset and still be legal in SCCA F stock? I should know this but I don't. Thanks for the help. I get to co drive the car this season. Should be a hoot.
No. Must run 19x9's, offset between 36 and 48 to be legal. And 3.73's are not the gear you want..... I have (and found out that it's best to have 3.31's unless you are running postage stamp lots.
Signed,
Sam 2010 FS National Champion in a 5.0/Brembo car Strano
Signed,
The tire diameter plays a huge effect on overall gearing though. Sam do your auto-x tires measure the same height as stockers, or are they shorter? If you have shorter tires, his 3.73s might be equivalent gearing with stock height tires.
Check this... http://i319.photobucket.com/albums/m...-ratios_97.jpg
The 3:31 is the ratio of choice, unless you like lots of shifting on an autocross course. My 2006 with a 3.55:1 axle works pretty well on the autocross courses I run on, and the (2011 with a 3.31) is about the same as a (2006 with a 3:55).
