Diff spit up a bit on track; cause for concern?
Old Apr 9, 2011 | 10:34 AM
DPE's Avatar
DPE
Default Diff spit up a bit on track; cause for concern?
Did my first track day in my 2010 GT (3.73 axle package) yesterday. Great fun, and the car did well. Only issue I noticed was that the diff spit up some fluid out of that little spring loaded pressure relief (?) valve thing on the right side of the axle. The car is near new, with 1500 miles on it. I seem to recall someone said this might happen, which is why I checked.
The question is, is this an issue to be concerned with? Or does it just puke up a bit every time it gets hot? Or was it slightly overfilled from the factory and when the fluid got good and warm it had to get rid of some? Just curious if this is a problem or just something that happens and I should just wipe it off and go on. And possibly check the fluid level and top off? Thanks for any help.
Phil
2010 GT
Old Apr 9, 2011 | 10:48 AM
JAJ's Avatar
JAJ
Phil
2010 GT
There's a TSB on that problem. Ford part number AR3Z-4A058-B fixes it.
Old Apr 9, 2011 | 01:40 PM
parchisi's Avatar
parchisi
I noticed my 2011 did the same thing, I haven't been worrying about it though...perhaps I should.
Old Apr 9, 2011 | 07:19 PM
Argonaut's Avatar
Argonaut
Its not a problem, they all do it when pushed hard. Some guys have fabbed up catch cans.
Old Apr 10, 2011 | 10:11 AM
DPE's Avatar
DPE
Thanks for the info. Sounds like that TSB part may fix it. Rather not have the axle puking after every event if at all avoidable. I'll order up one of those parts and get it put on and see how it does in a few weeks if I can get back to the track. Will post about it on here too, as it sounds like that could be helpful to a number of folks if it works.
Phil
2010 GT
Old Apr 11, 2011 | 06:20 AM
2005Redfire6's Avatar
2005Redfire6
Catch can on a diff, thats a new one!
Old Apr 13, 2011 | 03:38 PM
Norm Peterson's Avatar
Norm Peterson
Endurance levels of corner-carving do add a few requirements that you won't see very often at the local 1/4 mile. Cars running NASCAR cup and endurance road race series are even apt to have differential coolers complete with a pump driven off the driveshaft.
Norm
Old Apr 14, 2011 | 04:37 PM
JAJ's Avatar
JAJ
Phil
2010 GT
I installed the TSB part a week ago and did my first trackday in the new car on Monday this week. I inspected the underside today and I had no leaks at the diff (or anywhere else for that matter). Of course it might have been ok anyway, but with the turkey baster fitting, there was no mess.
Old Apr 14, 2011 | 11:21 PM
DPE's Avatar
DPE
JAJ, that's good news. Mine just came in at my dealer today, I just have to go pick it up and get it put on. Hope to be back at the track in a couple weeks to try it out. I wasn't being totally lame, but this was my first track day in any kind of muscle car and it never got over 60 degrees and I only ran 4 20-minute sessions. Suffice to say, it's only going to get worse for my car once I get comfy with it and the temps warm up . I suspect without the part you would have seen a little leakage even taking it pretty easy, especially given the extra power you have with the 5.0.
Too bad this isn't just a standard part on the car, but I get the cost factor and if it's fixed for $50 I can live with that. And yeah, I could have probably gotten it warrantied, but for $50 I'll save the hassle of taking my car in
Phil
2010 GT
Old May 13, 2011 | 05:00 PM
corruptor's Avatar
corruptor
Sorry for resurrecting a semi-old thread but does anyone know if TSB 10-3-7 was applied to 2011-2012 models? parchisi, do you still have fluid puking out the rear diff?
