Advice on my front end "clunk" noise
I've had the Roush springs for three years, and when I first installed them with the Koni shocks got a squeak in the front right. Had everything lubed and the squeak went away.
Just took the car out of winter storage and now I have a clunk noise on the front right. Do you think I need to take a look at the strut tower or could it be that the bushings are tight from sitting all winter?
Sounds like either an endlink bolt or possibly the top strut nut itself is loose. The OE endlinks are the usual troublemakers, but I've had the top nuts on both my front Koni yellows back off enough to start talking at me. I forget what torque Koni calls for their top nuts to be tightened to, but I know for the yellows it's less than Ford's spec (on account of the adjusting mechanism running through it). Don't know what the STR.t's call for if you've got those.
Norm
Norm
Dragonus18
Sep 9, 2015 01:21 AM
