Can 275/35/19 actually fit the front of a 5.0
I bit the bullet and after measuring, i ordered 4 285-35-19 and put them on the Brembo wheels and they fit without rubbing.
suspension is stock. I do have -2 camber up front for auto-x but don't think it was necessary to fit.
VID walk around
http://youtu.be/ok8X6aM0ShI
VID walk around
nice. i'd like to rock those re-11's on a set of 19x10's or 9.5's but there's such a limited selection of good looking 19x10's that can actually fit up front with the bremb-hos. i'm okay with massaging the front fender to bring it out a little bit but I still don't think that'll do the trick. what did you say you were using for camber up front? i couldn't quite make it out in the video. (ford camber kit?)
I used the ford camber bolts and maxed out the adjustment for auto-x way before i put these tires on. around -2
I don't recommend using skinny crash bolts for safety reasons, the ford part is a full size bolt with a large cam lobe and the oem strut has the proper tabs for the adjustment.
