Front end alignment after installing Steeda Sport Springs
So, I installed a set Steeda Sport Springs, Koni STR.T shocks/struts and a pair of GT500 strut mounts recently. And, this weekend I finally got around to getting it aligned. Below are the before and after specs. The items in bold exceeded Ford's recommendations.
Before:
LF Camber -1.5, RF Camber -1.8
LF Caster 7.3, RF Camber 7.3
LF Toe -0.09, RF Toe -0.23
Total Toe -0.33
Steer Ahead 0.07
After:
LF Camber -1.4, RF Camber -1.4
LF Toe 0.09, RF Toe 0.09
Total Toe 0.17
Steer Ahead 0.00
While I like how good a job the tech did in getting everything within spec and identical side to side, the fact that I am now running with the camber at -1.4 concerns me a little. This is only .1 degree within spec. I've read about the pros and cons of running an aggressive camber, but I wonder if I should try to dial it back some using camber bolts. What do you guys think? The car is primarily a DD with the occasional spirited driving thru the twisties
Dave
Before:
Total Toe -0.33
Steer Ahead 0.07
After:
Total Toe 0.17
Steer Ahead 0.00
Dave
I thought -1.4 was less camber than -1.5, meaning it's less aggressive. I could be wrong though.
Also, were you in the car when he aligned it? Doesn't make sense that both settings would be the same when accounting for driver weight.
http://www.ozebiz.com.au/racetech/theory/align.html
You are fine, the fact the tech made them both equal and the fact they reduced the camber means you'll end up with a little less wear on the inside tread of the tires and also smoother transitions throught he twisties (depending on your overall suspension).
Lowering springs usually means less up/down travel of the suspension so if you have a high negative camber you may never get full contact of the tire to the road going through a corner. (bottom of the article says it all).
mikecaputo
08-22-2015 10:58 AM
