Eibach Pro-System-Plus Kit Info? Help?
Old Jun 11, 2012 | 06:46 AM
  #21
Norm Peterson's Avatar
Norm Peterson
Originally Posted by 2008Vert
I should have gone with dampers first, but was kinda in shock that my car didn't even have a rear sway bar. Why the heck would they not put a rear sway bar on it??
Because it was possible for Ford's suspension team to obtain the desired handling behavior without it. And with a convertible, slightly softer suspensions are usually called for at the OE level simply because the convertible chassis is more flexible and carries a greater tendency to develop creaks, groans, and rattles over time.
They aren't magic. A rear bar on a stick-axle car should never be considered as anything more than the final fine-tuning handling balance tweak. Truth is, street-intended rear sta-bars on any solid axle car don't reduce roll by enough to matter.
I have read several places that the STB is not really helpful on the S197's and I can certainly see it being a hardly noticeable difference. Just my experience but it did seem to help the vert.
The convertible chassis is quite a bit less rigid than the coupes, so an item that doesn't stiffen a coupe up all that much will be somewhat more effective at stiffening a drop-top. IOW, it's easier to justify installing these things on a convertible.
There is also the perception issue. A STB will change the way the car's structure vibrates, which will provide a feeling of greater stiffness simply because you don't feel all the little vibrations quite as much. That can happen without the overall chassis stiffnesses taken between the front and rear suspension mounting points increasing much at all.
Dampers really are the items most in need of upgrade. As far as adjustables go, it's not that you have to keep tinkering with them in order to justify buying them. It's that you can tweak them and put them at the best settings for you, which you obviously can't do with non-adjustables. Once you've done that, stop.
That said, you can also develop two or more sets of settings for specific purposes and swap between/among them. Don't overlook the benefit in being able to dial them softer than your usual setting for when you or a passenger really needs or wants a softer ride.
Norm
Old Jun 11, 2012 | 07:11 AM
  #22
Norm Peterson
Originally Posted by JJP SuperStang
The pops has a 2006 Boxster S. Tiny thing and it can turn! I have Nitto NT555 front and back on the car. 18" rims. 275/40/ZR18 size of tires front and back.
You won't ever get the same nimbleness or handling feel as your pop's Boxster as there's way too many differences between the two cars. But you can get pretty close to matching the numbers, even with all that extra weight up high in the front.
Next time around, NT05's would probably help, as would 18x9.5 or 18x10 wheels if your wheels aren't that wide already. No stagger, please.
Norm
Old Jun 11, 2012 | 03:50 PM
  #23
snicksnipa's Avatar
snicksnipa
I am still amazed for the price at the amount of grip the Sumitomo HTRZ III's summer's have, it gets close to Michelin Pilot Sport PS2's for half of the price. I read a pretty post about old track fox body's running without a rear sway bar to reduce oversteer and allow for some inside tire lift on turns.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
