Koni SRT or Sports?
Norm
Thanks for the great info and I appreciate your insight on the Metco LCA's, I did have Rick at Metco switch the delrin bushing to poly which he advised would be better for my intended use. The one thing I really like is that they have grease fittings so keeping them lube should not be a problem.
Based on your statement " Yes, you can probably crutch the situation with a softer rear bar than what you'd run otherwise, but it seems better to avoid the problem in the first place so that you don't need to do the band-aid either."
Should I stick with the softer stock sway bars?
also, should the stock springs be addressed or left alone?
I appreciate your help
I'm running Sports on my DD and I feel like I should have gotten the SRTs because I don't use the adjustability enough to justify the purchase. If you auto-x'd, my answer would differ but you will find yourself riding around on full soft anyhow with the sports which is comprable to the SRTs so why not just save some money and buy those. Just my 2 cents.
I have the str.t's now and would not want to firm up the travel in my suspension at this point, even if I could. If I planned to track the car, I would probably spend the extra $$, but for a DD...no way.
I also believe the str.t's have a lifetime warranty as well.
You're correct, Koni offers a lifetime warranty on their STR.T. Like I've told everyone else, I enjoy the adjustability of the yellows. Whether you adjust once or mulitple times you can adjust to your liking, I enjoy the comfort of adjusting to how I like car to ride.
There almost certainly are a few things you can do to free up the poly a little further for cornering, though. The simplest one is to make sure that the flat faces of the poly bushings extend just short of the ends of the inner sleeves (aka "ferrules") so that a tiny bit of sleeve sticks out past the poly (maybe under 1/32" total?). A belt sander or even a bench grinder will work for this. Bushing life may be shortened, and you might want to lube them a little more frequently, but poly bushings should be considered "wear & maintenance parts" anyway. Think about it a bit first.
Norm
I'm running Koni Sports with UPR/Eibach Pro springs and UPR suspension on my car. It works very well. I had to adjust the Konis a couple of times until I found a setting I liked. I don't think the STR.Ts would've worked well for me.
I have a 2013 GT vert with the Brembo package, it is stock except for Metco LCA's and an MGW short throw shifter. It is a daily driver that gets to go corner carving every chance I get, I have no intentions to race or autox.
My question is, which shocks are most suitable for a DD/cornering set up?
I like the fact that the SRT is less expensive but, I also think the adjustability of the Sports would be useful.
My future plans for the car are simply to make it handle and corner better, right now it still gets a little too deep into the corner but the LCA's have improved the throttle steer coming out of the corner. I may look at sway bars at a later date.
Any input from owners of these shocks on a brembo car would be greatly appreciated.
thanks
thanks
Also it will depend on your pocket ($).
