High Intercooler Temps...HELP
So...I was on my way home from the dyno last night and I noticed my intercooler temp was around 145-150...I thought that was a little high considering it was only 50 degrees out. So today on my way home I noticed it was hovering around 160 mark...so as I startted to slow down.. it almost pegged the gauge!! I crawled under my car and where the intercooler pump is at I didn't feel anything cold at all..
So I checked the reservoir and its definately not circulating.. I'm assuming I need a new intercooler pump?? Or is there a fuse I need to check?I took the fuse panel off and none of the fuses were labeled.
The good news was I dynoed at 345 rwhp and 388 tq......and this is with CAI, off road pipe, and chicane pulley. Oh yea I have a 02' SC S-281
Thanks, Jack
Thanks, Jack
RE: High Intercooler Temps...HELP
Nice numbers! Thats way too high, but you already knew that. I would the fuses. Could just check the manual and there should be a diagram detailing ou each fuse. If none of the fuses are blown than I would think it would be the pump.
