Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Belt Tensioner
Old Oct 26, 2008 | 09:36 PM
Big Top Gt's Avatar
Big Top Gt
I broke a tensioner this morning.
Of course, it was because I left a 1/2" ratchet in the front of the tensioner and the belt wrapped around it when I started it, but that's not the point.
Buy a better tensioner. Ha!
Seriously though, I think the reason you'd want a new tensioner is because when you start making a bunch of power, it puts a lot more stress on the belt and pulley system. Remember, that 500+ HP you're making is spinning the crank harder.
That causes a weak tensioner to bend, and eventually break.
Again, that's assuming you're not as dumb as me.
Old Nov 5, 2008 | 04:22 PM
SCs197gt's Avatar
SCs197gt
On A Mish
My tensioner sheered in two pieces just after I installed the 550 kit. My gf popped the clutch after me debating on whether or not I should let her drive it and crack there it went. I installed saleen's that they have on the xtreme and no problems since. Of course the gf doesn't drive it anymore lol
Old Nov 9, 2008 | 11:35 AM
AKRA's Avatar
AKRA
I was having problems with belt slippage. Not only was my boost gage all over but you could hear a sweeking noise from the twisting of the stock tensioner under load. Especially when letting off the gas.
I called JDM and they sold me the Roush Tensioner. Because I have the 3.4 pully I ended up having to switch to the Goodyear Gatorback 108 inch belt because the Gates 107.5 inch belt was to tight. It did help my slipping problem.
Old Nov 9, 2008 | 11:21 PM
cobraT's Avatar
cobraT
You guys want a good tensioner? This is a tensioner!
http://www.thump-rrrracing.com/Parts.html
Old Nov 10, 2008 | 08:57 AM
mikebna's Avatar
mikebna
no kidden, that looks like one helluva tensioner!
mike
Old Nov 10, 2008 | 09:57 AM
unclemilti's Avatar
unclemilti
Its nice, but WAY overpriced.
Steeda has basically the same thing for less than 175 bucks.
Old Nov 10, 2008 | 04:09 PM
cobraT's Avatar
cobraT
I know this is not cheap. Steeda's is a welded piece added to a stock tensioner, I believe, not billet aluminum no welds. Probably a little over-kill except for the extreme horsepower applications. I believe JDM is uses them.
Old Nov 12, 2008 | 06:29 PM
AKRA's Avatar
AKRA
JDM is where I bought the Roush tensioner. Jim at JDM told me he thinks the Steeda was a reinforced stock tensioner. The stock tensioner spring has much less spring force than the Roush tensioner. The extra spring tension is supposed to help keep the belt from slipping.
vargas
Jun 17, 2017 12:17 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
MacSerio
Sep 27, 2015 01:05 PM
rafotree
Sep 22, 2015 03:55 PM
