leaking transmission fluid from transmission dipstick
![Default](https://mustangforums.com/forum/images/icons/icon1.gif)
yeah its not like its pouring out or anything, it just leaks out when i fill it up for the next week and im finally tired of buying transmission fluid and just want to fix it. how would i go about that? if its the gromet (sp? is that even what the things called?) how would i replace it, and is there an easier way?
thank you
thank you
there is a O-ring on the end of the tube that presses down into the tranny housing, if you can unbolt it, either replace the tube (whcih has new O-ring) or pull tube and replace ring.
