A/C Line ( Vacuum Line/Tube)?? HELP!!! HOT SEASON!!
Old 08-19-2012, 01:35 PM
slikz
slikz's Avatar
Default A/C Line ( Vacuum Line/Tube)?? HELP!!! HOT SEASON!!
Name of auto part? My A/c is only coming out through my upper vents (defroster). I need to connect the vacuum line (tube) that disconnected since they are fragile. What would the auto part be called at autozone/napa, etc..? They no longer sell these parts at the dealership since the vehicles a bit older.
Here's a picture of where it snapped.. (pictures are from another thread)
HELP, PLEASE!! The thin line is where it snapped and fell off, over time.. A/C is only coming out of the upper vents due to this line being disconnected. What is it called at the auto parts store, or, where can I find a line/tube to reconnect it?
slikz is offline
Old 08-19-2012, 09:07 PM
slikz
slikz's Avatar
This is where it disconnects but on both ends.
slikz is offline
Old 08-20-2012, 08:43 PM
belairbrian
belairbrian's Avatar
It's just vacuum line. Ford chose to use hard plastic sections. You can replace it with rubber line.
belairbrian is offline
Old 08-23-2012, 02:01 PM
gyea
gyea's Avatar
I agree with belairbrian you can use rubber line for vacuum lines and then wrap it in wire split loom to protect it from heat and fluids just measure the barbs and get the appropriate inside diameter hose
gyea is offline
Old 08-24-2012, 10:31 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Mine did the same thing. I went to AutoZone and bought this and it worked perfectly -
http://www.autozone.com/autozone/acc...er=477679_0_0_
Good luck,
Matthew
Matt's 95 Stang is offline
Old 08-26-2012, 12:06 AM
slikz
slikz's Avatar
THANKS!!! ^
slikz is offline
Old 08-27-2013, 11:01 PM
mike33756
mike33756's Avatar
OMG! I literally have spent the last 2 days trying to find an answer to this problem! Autozone even told me straight up they had no idea what that part was, and I couldnt find it ANYWHERE in ANY catalog or forum...So THANK YOU! I just ordered that piping and the covering, will finally have A/C in my 'Stang.
THANK YOU!
mike33756 is offline
Old 06-22-2019, 04:50 PM
Ben Northrop
Ben Northrop's Avatar
Default Thanks
Thank you for the explanation and pictures of the vacuum line. This was exactly what was wrong and I fixed it for 2.00.
Ben Northrop is offline
tienvg
08-15-2007 10:53 PM
mike.0621
05-22-2007 12:55 PM
CobraStangGT16
01-03-2007 06:14 PM
rw98
05-28-2006 12:36 AM
Gun Jam
05-12-2006 01:09 PM
Quick Reply: A/C Line ( Vacuum Line/Tube)?? HELP!!! HOT SEASON!!
