Looking for clutch advice, looking at stage 1 options.
My clutch is slipping and I need it replaced. I can't find a reasonably priced stage 1 kit that isn't 700+. I've seen spec, the flywheel is expensive as the friction and pressure plate, and doesn't come with the throwout bearing. My car only has a BAMA 93 tune, dual exhaust conversion and a CAI. Looking to add 4.10 and maybe some better injectors, plugs, distributor and fuel pump. Do I even need to go to stage 1 or will I be fine with the Luk clutch kit?
redfireshaker06
04-17-2013 04:49 AM
