Oil in coolant
Old 03-26-2019, 08:51 PM
Skidball
Skidball's Avatar
Default Oil in coolant
Tonight I changed the oil filter adapter gasket. Had to remove oil cooler first. Everything else checked out. Did a combustion gas check on radiator. Was good. Just oil in the coolant.
Skidball is offline
Old 03-27-2019, 06:32 AM
08'MustangDude
08'MustangDude's Avatar
That is more like a heat exchanger, it cools the oil to the coolant temp.
Inside, it's broken, allowing oil to pass into the coolant.
08'MustangDude is offline
Old 03-27-2019, 08:49 PM
Skidball
Skidball's Avatar
Broken ? Like how ? Cracked ? Or internal ? I got the assumption that the adapter to block gasket goes bad, and it looked bad, that the oil pressure pushes oil into the coolant ?
Skidball is offline
Old 03-28-2019, 06:39 AM
08'MustangDude
If it's not the gasket, then it's internal.
The coolant passes through the cooler, and the oil passes through along side
the coolant passages. IF a passage gets a hole in it, oil and coolant will
mix.
Old 03-31-2019, 07:35 PM
Skidball
Skidball's Avatar
thank you
Skidball is offline
302Travis
16
05-01-2014 08:30 AM
Doublevision
25
05-28-2013 09:20 PM
1fast5089
SVT Forums
12-24-2010 11:00 AM
moosestang
05-27-2008 08:08 PM
88BlueGT
10-27-2006 01:59 PM
Quick Reply: Oil in coolant
