2014 Shaker internal HD
Old 04-19-2019, 01:25 PM
EricG
EricG's Avatar
Default 2014 Shaker internal HD
Has anyone every tried to upgrade the internal storage on the Shaker system?
Not that is all that hard to use a thumb drive but vioce works better with the music stored on the system.
Thanks
EricG is offline
Old 04-19-2019, 05:36 PM
08'MustangDude
08'MustangDude's Avatar
Depends if it's integrated or an actual removable HDD when you open it up.
Voice quality should not matter no matter where it's stored. You can make LossLess
MP3 files, or use a 256K or better bit-rate, with 48000Hz sample rate when ripping
music to a USB storage device. The stored on HDD in the Shaker is with the best
bit rate, and sample rate to produce LossLess audio. All that can be achived
using USB drives too, when ripped correctly.
08'MustangDude is offline
Old 04-25-2019, 11:25 AM
EricG
EricG's Avatar
Thanks. That is what I was thinking. Just wondering if anyone has tried this before. Guess I'll watch the wrecking yards and see if i can find one to take apart and try.
EricG is offline
Old 04-25-2019, 05:46 PM
08'MustangDude
They're easy to take apart and look at...
If I rip a CD, I rip them to MP3s at 320Kbps, with 48000Khz sample rate.
Now that I have an Eonon android unit, I can use the FLAC codec, which is lossless.
For saturated music such as hard rock, metal, arena, pop, electronic and house music,
320kbps will give the best results. No MP3 is lossless, but the higher the bitrate, the
better the sound, but larger the file.
You won't be able to tell the difference from a CD player, satellite, or HD radio -vs- an .MP3 at
320Kbit/48000kHz rates in a vehicle. At home with a theater system, you will... I have two
64Gig USB drives for my Eonon, and all my audio is 320Kbit/48000Khz.
However, in my VW Jetta, all my movie and tv series ripped audio is 192Kbit/44000Khz. I drive 450+
miles a day, 4-days a week and I listen to a LOT. I have every Star Trek series, and movie as .MP3 files,
plus a LOT more, for 120gig of stuff... This is on a 120GB SSD plugged into the MDI port. You may
want to see if your Radio USB ports can handle an external HDD, Laptop drive or SSD. Then you can
RIP everything you got to it.
I had a tablet in my former Charger, mounted to the driver side sun visor, and put everything I had on
that. Power and Audio ran down the "A" pillar, the audio to the radio AUX jack. I used a seperate
USB power supply for the tablet.
I been doing stuff like this for 20+ years...
yukmouth
07-27-2011 09:59 PM
svastano
09-30-2010 07:50 PM
twinturbomustang
02-08-2007 02:13 PM
ninja205
06-07-2006 06:21 PM
Mustang Bob
04-25-2006 08:42 PM
Quick Reply: 2014 Shaker internal HD
