Battery Draining
Old 05-04-2019, 09:43 AM
MikeAlbarella
MikeAlbarella's Avatar
Default Battery Draining
Hi People,
I need some advice. I have a 2001 Mustang GT 8 cylinder manual Tranny, There is an aftermarket stereo in the car, I bought an original Stereo and want to have it installed in place of the aftermarket one.
This is the issue, if I let the car sit for four days it will not start without a jump. I am wondering if there may be something wrong with the radio connection which is draining the battery. Sometimes when I start the car, the radio does not go on, if I shut the car off and start it up again it works. Any ideas where to look for the problem?
Thanks
Mike
MikeAlbarella is offline
Old 05-04-2019, 10:52 PM
imp
imp's Avatar
Originally Posted by MikeAlbarella
Hi People,
Thanks
Mike
Determine which fuse is feeding power to the stereo and remove it. If the battery then remains charged, there is something haywire with the stereo wiring; maybe it's internals are not shutting off.
More sophisticated testing using ammeters, etc., is possible,and for that matter, the stereo may NOT be the cause, but it's a start.
imp is offline
Old 05-06-2019, 06:46 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
With an aftermarket radio and inconsistent symptoms like what you're having, my kneejerk internet diagnosis is jinky wiring.
fastbackford351 is offline
Old 05-11-2019, 12:12 PM
tadpole1969
tadpole1969's Avatar
had the issue once ,found out it was the factory amps in the trunk drawing the power after car was off
tadpole1969 is offline
Old 05-23-2019, 10:43 AM
MikeAlbarella
Thanks for the advice guys, Here is the update. I brought the car in to car toys and they diagnosed that the draw was up to the PCM instrument cluster. I then brought the car into the Ford Dealership and they also said it was the PCM Cluster. My question is this. Is there any other tests that can be done to rule out the PCM cluster? The cluster costs about $900.00 and from what I have been reading, the cluster controls many other electronics that may be drawing the current when the car is off. Is there a way to test the other electronics to isolate the PCM cluster before I have to pay to get it replaced?
Old 05-25-2019, 05:34 AM
fastbackford351
Foghorn Leghorn
I'd damn sure be hitting up the bone yards or Ebay for a replacement before I paid 900.00
Yello4u
12-11-2009 03:29 PM
dan_h
02-23-2009 06:52 PM
cw55
04-14-2008 01:33 PM
modularmadman
03-05-2008 05:28 AM
razol
04-24-2006 05:23 PM
Quick Reply: Battery Draining
