Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
busts up under a load
Old Oct 17, 2008 | 08:13 AM
spltank's Avatar
spltank
Default busts up under a load
Thats the best way I have to describe what my 88 lx SD car is doing.
If the car is sitting still it will rev like it should. When it's taken down the road the car will accelerate and do like normal and will rev over 5K no problem as long as you stay out of the throttle. WHen the throttle is layed down the car acts like you spraked it with out the bottle open.
Specs.
CAI
cobra intake
MSD dist
adj fpr
BBK shortys, H, and flowmasters
Udnerdrive pullies
65mm TB
What we've tried.
Adjusted Fuel pressure, changed fuel pressure gauge to verify.
set timing
cleaned injectors
reset TPS
replaced plug wires
swapped dist
Please help.
Neill
Old Oct 18, 2008 | 01:58 AM
Night Terror's Avatar
Night Terror
run codes...
Old Oct 18, 2008 | 04:41 AM
spltank's Avatar
spltank
Ran the codes and came back with EGR (which is not on the car) and a temp sensor "out of range" (replaced it).
Neill
Old Oct 18, 2008 | 08:01 AM
Tony71502's Avatar
Tony71502
How's your clutch?
Are any of your ignition wires crossing or tight against the block? I had similar problems when I put some cheapo ignition wires on, one wasnt long enough and was taunt against the block.... That bitch mustve been arcing or somthin but when I took them back off the problem was fixed.
Old Oct 18, 2008 | 09:14 PM
spltank's Avatar
spltank
THe cars an auto. I replaced the plug wires 3 times and still have the same problem.
Thanks for the ideas though!! Kep em coming.
What are the chances of a computer problem?
Neill
Old Oct 19, 2008 | 02:14 PM
spltank's Avatar
spltank
Fixed.
It was the MAP sensor.
Neill
belam
May 6, 2016 06:24 PM
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
lmurf60
Sep 24, 2015 10:07 PM
03blackwidow
Sep 20, 2015 02:36 PM
