Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
LS1
Old Dec 24, 2007 | 10:05 AM
  #201
SpecterGT260's Avatar
SpecterGT260
Default RE: LS1
i really dont think GM would have a leg to stand on, the fact that they are hemi's means the heads are completely different. other than that, howmany ways can you really build a block in a production car? most smallblocks anymore are pretty similar, you just tweak a few things here and there.
Old Dec 24, 2007 | 01:36 PM
  #202
TommyV8's Avatar
TommyV8
Default RE: LS1
The new "Hemis" do not have the hemispherical combustion chambers that the old ones did. It's just a name used by DC marketing to sell vehicles.
Old Jan 2, 2008 | 07:47 AM
  #203
S8ER01Z's Avatar
S8ER01Z
Default RE: LS1
Yep,
The New Hemi isn't really a hemi.
Old Jan 7, 2008 | 06:46 PM
  #204
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ok, could someone tell me this. would my 350hp 3rd gen beat an LS1 Camaro?? (or at least hold even
my specs:
350 sbc with "mild" cam and P&P
700R4 (for now, soon the 6 speed and 3.73's from the donor 4th gen will be in there)
3.23 open rear
650cfm Holley carb
2 1/2 straight pipe all the way back
3452lbs with me in the car
Old Jan 8, 2008 | 07:56 AM
  #205
S8ER01Z's Avatar
S8ER01Z
Default RE: LS1
Would need to see rwhp/trq numbers to even have a good guess.... aside from that take it to the track and find out. I want to say yes but I've seen cars make great peak numbers and have nothing under the curve to get things done. I would say you have a shot considering you are ~200lbs lighter (was that full fuel weight?) and make ~350hp but your trans and open diff (along with the 3.23s) are going to hold you back.
Old Jan 8, 2008 | 11:24 AM
  #206
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ORIGINAL: S8ER01Z
sorro, it put down 350hp and 385ft/lbs at the ground
and yes, that was full weight
Old Jan 8, 2008 | 11:27 AM
  #207
Sarge_13's Avatar
Sarge_13
Default RE: LS1
ORIGINAL: 1990CamaroRS
ORIGINAL: S8ER01Z
I'd say you have a very good possibility if you don't send your tire up in smoke.
Old Jan 8, 2008 | 11:41 AM
  #208
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ORIGINAL: Sarge_13
ORIGINAL: S8ER01Z
so from a dig, he would win, but from a roll, i would stand a better chance??
Old Jan 8, 2008 | 01:40 PM
  #209
S8ER01Z's Avatar
S8ER01Z
Default RE: LS1
If you make that to the tires..I say you have it in the bag (save for having a 'one tire fire' incident [8D])
An LS1 is making ~300rwhp and has a few hundred lbs on you...I don't see where you would have a problem from a dig or roll aside from traction.
Old Jan 8, 2008 | 05:46 PM
  #210
98LS1's Avatar
98LS1
Default RE: LS1
Was the car dyno'd? Or are you guessing?
