Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
LS1
Old Jan 8, 2008 | 06:16 PM
  #211
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ORIGINAL: 98LS1
ORIGINAL: 1990CamaroRS
sorro, it put down 350hp and 385ft/lbs at the ground
and yes, that was full weight
Was the car dyno'd? Or are you guessing?
it was dynoed, but i can't find the sheet
Old Jan 9, 2008 | 12:52 AM
  #212
1BAD3V's Avatar
1BAD3V
Default RE: LS1
What kind of 350 motor is this you have? Dont the stock 350's that came in the 3rd gen's only dyno in the 200's, like low to mid 200's?
Old Jan 9, 2008 | 10:16 AM
  #213
S8ER01Z's Avatar
S8ER01Z
Default RE: LS1
http://www.svtperformance.com/forums...d.php?t=449809
Check this out....Bone stock 02 3.23 Geared Automatic Z28 in good weather....
60' 1.921
333' 5.442
1/8th 8.327
MPH 85.28
1000' 10.832
1/4 12.957
MPH 105.88
Old Jan 9, 2008 | 10:24 PM
  #214
TommyV8's Avatar
TommyV8
Default RE: LS1
^The trap speeds look about right (same as mine when stock) but that 60 ft is KRAZY for factory stock![:-]
Old Jan 10, 2008 | 07:44 AM
  #215
S8ER01Z's Avatar
S8ER01Z
Default RE: LS1
Hell yeah it is!! On GSCs none the less!
Old Jan 10, 2008 | 12:31 PM
  #216
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ORIGINAL: 1BAD3V
my car started out life with a 3.1 v6, if bought a slightly used 350, and rebuilt it. evidentally the guy who owned it before me had built the motor slightly. it is a GM performance crate motor though
Old Jan 31, 2008 | 12:20 PM
  #217
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ok, i've got another question. i was reading up online about the LS1, and i came across an article that said the LS1 was a joint venture between GM and Honda for the engine design, is this true??
Old Jan 31, 2008 | 02:04 PM
  #218
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: LS1
No it's not true. I have a book that details the development and building of the LS platform. It was 100% a GM deal.
Old Jan 31, 2008 | 02:39 PM
  #219
1.5LofFury's Avatar
1.5LofFury
Default RE: LS1
ok, thanks. just got kinda confused on that
Old Jan 31, 2008 | 05:05 PM
  #220
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: LS1
ORIGINAL: S8ER01Z
Would need to see rwhp/trq numbers to even have a good guess.... aside from that take it to the track and find out. I want to say yes but I've seen cars make great peak numbers and have nothing under the curve to get things done. I would say you have a shot considering you are ~200lbs lighter (was that full fuel weight?) and make ~350hp but your trans and open diff (along with the 3.23s) are going to hold you back.
Engine specs?
